03 6.0 Escalade Need MPG Improvement
#21
Originally Posted by timvan
Ouch, 10.9 ....I got 11.7 with my H2
what is the throttle body bypass, and intake tube? Im assuming emission related?
the intake tube is from airraid, it removes the factor resonator that gives you a cool sound..... a sound i hate when towing. so loud, i cant stand it.
gonna have to check the air fuel difference and milage with the stock one back on and see if it doesnt change. if the stock resonator pipe doesnt decrease my milage.... its going back on.
#22
I have been experimenting with trying to save some gas on my commute, and I have noticed that the MPG on these engines takes a dive really fast as you apply even a small amount of acceleration. I find that if I drive behind a semi-truck (not drafting but using it for pacing), that I can control my foot enough to keep things 'in the zone'. This morning, I got 18.4 MPG on my 22 mile drive of freeway and surface street driving (net elevation gain). But I have to limit myself to painfully slow acceleration and find it handy to lose speed going up hills and get it back on the downhill side. Even with 5 lanes on the freeway and at 6 AM, it is still hard to be able to keep your own pace, so peak MPG is never realized as you have to brake for idiots and then regain the speed. But it is quite an improvement over the 13 MPG I usually get when using the throttle a lot to keep the microscopic following distance that urban freeway driving requires
Note: I am not sure how accurate the Average MPG meter on the truck is on such short measurements (22 miles). It is possible that I am doing some things that are fooling it a bit. Like coasting in Neutral on the off ramp.
#23
i like to take my total miles, and divide it by the # of gallons to the tank, for my "overall MPG"
the 18mpg you got on your 22 mile commute would be hard to repeat on a full, or even half tank of gas.
take it easy.
#24
I have ben running a Radix for a little while. I have a Vac\Boost gauge and of course I was very interested in the effect of the blower on my "going to church on sunday" type of driving. I lost under 1 mpg City and no effect on Highway.
Getting to the point, I monitor the vacuum a good bit and find I get my best mpg keeping it in as much vacuum as possible. At times on flat road I can be cruising along and adjust my foot a tiny bit and increase the vacuum by 2 inches without loosing speed.
I installed Flex-a-Lites on my 03 Z71 5.3 and got 2 mpg city easy. That mech clutch was murder on it from light to light in the hot summer. Made the AC ice cold 100% of the time too.
#25
drives me nuts when the a/c blows heat for 30 seconds. only does it here and there. im sure you guys are fimilar with it, arrggg!
ill be doing 05 electric fans when they get a few at the local boneyard.
too cheap to buy them new.
#26
Thanks guys!
I already have a custom tune for 87 octane, with the 6.0L and AWD It gets 13 in the city..
whats the likely hood of adding e-fans, getting 2mpg, adding headers ,2mph..and cat back =?mpg
is it a linear thing, will I get 6mpg more with calm driving and the above mods?
Thanks Again!
Thanks Again!
gaps
Oct 15, 2015 02:53 PM
Tigger Welder
Oct 1, 2015 08:41 AM
mitchellmade
Sep 27, 2015 08:27 PM
ClintBeastwood
11
Sep 13, 2015 11:49 PM
03, 2005, 53l, 60, chevy, escalade, gas, gm, improvement, improvements, improvments, inprovement, mileage, mpg, performance, silverado, suburban
