02 8.1L Wont start! HELP!
Old Sep 22, 2009 | 06:04 PM
Ender06's Avatar
Default 02 8.1L Wont start! HELP!
Ok, so I ran the tank low on fuel and left it setting a day or two, and I decided to change my DRL bulbs, but they were rusted, so I went into the fuse box and messed with some fuses and pulled the DRL fuse so I could dig around in the socket. Got done, replaced fuse, and now the truck WON'T START! It cranks, and will fire just a little, sometimes it'll start, but just for a second or two, and its reall rough. I checked the fuse box, everthing seems fine. All I can think is the fuel pump is weak or something. I don't have means of checking fuel pressure right now. My Preadator isn't getting any check engine lights. WTF
Old Sep 22, 2009 | 11:02 PM
Dgrown's Avatar
try tapping the bottom of the tank and if it starts then it means that your fuel pump is toast
Old Sep 22, 2009 | 11:04 PM
Ender06's Avatar
OK, thanks, will do, but whats tapping it going to do?
Old Sep 22, 2009 | 11:20 PM
Dewey's Avatar
if the motor is shot in the pump or is jammed, then tapping it will usually knock it loose. (at least temporarily)
Old Sep 22, 2009 | 11:25 PM
Dgrown's Avatar
you do have to give the bottom of the tank and pretty good whack
Old Sep 22, 2009 | 11:27 PM
Ender06's Avatar
heh, I was just getting ready to ask how hard to git it. I got a hammer in the truck somewhere. i might go try it right now
Dewey's Avatar
a rubber mallet works nicely
Old Sep 22, 2009 | 11:38 PM
Ender06's Avatar
Just tried, beat the **** out of the tank, no start! I can't even hear it prime though, this has to be it......I think
Old Sep 23, 2009 | 12:02 AM
Dewey's Avatar
check your relays in the fuse block under the hood. they can come loose which you can wiggle them with the ignition on. also, try to shift to 1st gear and then back into park. if that works then your neutral sensor is bad. my truck has done that twice now since i've had it.
Old Sep 23, 2009 | 10:24 AM
Ender06's Avatar
Absolutely NO fuel pressure!!! Checked this morning. I want to see if the pump is getting power. How is the best way to do this??
