0.070" mill, any PV probs?
I have a set of 5.3s I have had milled 0.070" to get around 10.5:1CR. These are going on my Silverado and I want to know if I will have any PV clearance problems with the stock 5.3L cam.
I'm also thinking of putting the stock cam out of my 01Z28 into the truck (it is free and I DO NOT want to change the RPM band much/if any). Would I have clearance issues with that?
I want to find out ahead of time so IF I need to flycut the pistons, I can have the tool here when I START the swap (so the truck does not sit apart for a week+).
as I understand it (since nobody around here seems to know the pin height of a stock 5.3), 0.050" mill works out to 10.3:1 so 0.070" should be right around 10.7-10.8:1 and should be well within the limits of 91 with ceramic coated chambers.
Originally Posted by silverbrick
this is true. intake fit problems you may see. also, with .045" milled you see ~10.5 so you should see considerably more with .070.
good luck, maybe try some HUGE gaskets
with a stock .054 gasket.
The pin height is probably the same as a 5.7 it's the same crank and rods. The piston comes out of the hole between .006 and .008 depending on who measures.
I have .055 milled off my heads and I don't remember if they were 56 or 58 cc's when done.
A 224 cam with the heads mentioned above with 2" intake valves is tight on the ptv.
Trust me I still use my truck as a truck. I tow a car trailer about once a week lately and there is constantly something sliding around in my bed.
Yank makes a converter that stalls to 3000 and retains all the stock towing ability.
But I am looking for a Nova for the new set-up.
zblee
Nov 11, 2015 12:41 AM
someotherguy
Oct 5, 2015 12:49 PM
gmcyukon
Oct 3, 2015 11:03 PM
PDPERFORMANCE
Sep 8, 2015 11:01 AM
