Yukon posi and precision ring pinion?
Old Jul 22, 2006 | 09:00 PM
OrlandoFL4.8's Avatar
Default Yukon posi and precision ring pinion?
Well, the shop didnt install the eaton posi like I had wanted, it was a yukon posi instead. Tried the search button using key work yukon and cant find crap but the vehicle model yukon. How good or bad is the yukon brand posi, and what is the quality of the precision brand ring and pinion?
Old Jul 22, 2006 | 10:19 PM
phasemaster1's Avatar
Isnt that just a g-80?
Old Jul 22, 2006 | 10:44 PM
2k5Squirrel's Avatar
14 Second Truck Club
g-80 is an eaton
Old Jul 22, 2006 | 11:39 PM
I have even searched the yukon web site and cant seem to find a unit that is posi for 30 sline, 8..5/8.6, 10 bolt? All I can seem to find are install kits?
Old Jul 23, 2006 | 01:43 AM
hog's Avatar
hog
Originally Posted by 2k5Squirrel
g-80 is an eaton
eaton makes teh Govlock which is the GM spec G80 locking rear dif. Eaton also makes the Eaton Carbon limited slip differential which only allows slippage in corners and never behaves like an open dif, the G80 always acts as an open dif unless the activating mechanism locks the rear dif. when axle speed difference is detected while under power. The G80 also doesnt lock at speeds above 20 mph.
peace
Old Jul 23, 2006 | 11:07 PM
Last Call's Avatar
TOTM: January 2007
After blowing an Eaton, I wanted change so I went with a Yukon posi.
After talkign with Randy ring and pinion, the tech told me that the Yukon posi was just as good or better than the Eaton. I have not driven my truck with this unit installed yet, so I cant really compare the 2 yet. However, the casing on the Yukon looks better than the eaton because it is more of an enclosed case, and doesnt have a huge "window" like the eaton did.
Old Jul 25, 2006 | 09:23 PM
Hey man, could you send me a link to this unit you are installing? I would really like to read up on it and havnt found sht on a 30 spline 10 bolt 8.5/.6 for my truck. As stated before, the shop put this unit in with out me knowing about it, but I did leave it open for suggestion that the shop could use similiar to an eaton posi.
-thanks
Old Aug 1, 2006 | 04:25 PM
MegalosZ71's Avatar
I've got a Yukon Dura-grip in mine but I don't have enough miles on the new parts to go test 'em out.
OHsixLS3
Nov 22, 2015 07:45 PM
turbo6c3
Oct 5, 2015 06:11 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
sTNT971
Sep 26, 2015 04:22 PM
