Yank Stall Won't Install!!!
Old Jun 21, 2007 | 08:11 PM
benvortec's Avatar
Default Yank Stall Won't Install!!!
I did a 6.0 swap and it did have a 4l80e behind it. I DID take the 4l60e flywheel off my 4.8 and install it on my 6.0 I jacked the tranny up and installed 4 or 5 of the bolts and then when i started checking on lining up my stall bolts i noticed that the stall doesn't have room to free spin and is pinned up against flywheel. What would cause this? Anybody ever had this problem?
Old Jun 21, 2007 | 08:16 PM
Derek @ EDO's Avatar
FormerVendor
did you remve the spacer from behind the 4l80e flexplate?
Its on the block.
Old Jun 21, 2007 | 08:38 PM
benvortec's Avatar
R U SERIOUS? I had no idea there was a spacer behind the flexplate??? Where exactly is it at and what must you do to remove it?
Old Jun 21, 2007 | 08:42 PM
FormerVendor
Yep, just pull off your 60e flexplate and you will see it. I think it prys right off i really dont remember but its easy to remove, you do not need any special tools.
good luck man!
Old Jun 21, 2007 | 11:02 PM
Colby 04's Avatar
I don't recall any spacer on mine (LQ4 with 80E flexplate)? I had about a 1/4" of gap between the 60E flexplate and converter when I got the bellhousing all bolted up...
Old Jun 22, 2007 | 12:14 AM
06sierra5.3's Avatar
if thats not it youre converter might not be in all the way. try and wiggle it and push it back a little bit. rule of thumb is you shouldnt be able to fit your fingers behind the converter when its installed.
Old Jun 22, 2007 | 12:44 AM
1SlowHoe's Avatar
Destroyer of Transmissions
Are you sure it had a automatic behind it before? Check for a pilot bearing. Otherwise make sure that converter is et all the way. 3 steps with a few turns between each step closer to the trans. If you have a pre-2001 (I think) 6L then you may have that spacer mentioned above. The engine has aluminum heads right?
Old Jun 22, 2007 | 03:39 AM
benvortec's Avatar
yea it's a 2002 model with aluminum heads
Old Jun 22, 2007 | 09:41 AM
adam1803's Avatar
If its a 2002 model then it should have the spacer. I thought the spacer was pressed into the flexplate though as i remember. How far are the teeth of your flexplate away from the block? If its more then about 1/4-3/8" then the spacer is probably still on there.
I would lean towards the converter not being in all the way. They can be a real pain to get in sometimes.
Old Jun 22, 2007 | 05:32 PM
benvortec's Avatar
Its on the block.
You always hook me up man! Took a chisel and a hammer and took the spacer off and now the trannys fittin great! Thanks
