Won't shift to 4th after Vette Servo install
Old 08-18-2010, 06:15 PM
JDScherz's Avatar
Default Won't shift to 4th after Vette Servo install
I just installed a vette servo today, and after a little mishap..snap ring wasn't all the way in, but luckly the heat shield kept all parts from scattering on the road. I returned after a very short smokey drive back to shop and replaced the cover and made sure the snap ring was in this time. On the way home I was pleased with the 1-2 and 2-3 shifts, but NO 4th gear??? Just wondering if anyone else has any suggestions??
I did just have a Black Bear tune prior to this install, but can't see that affecting anything??
Old 08-18-2010, 06:18 PM
TX Tahoe Z71's Avatar
You leave a washer out?
Old 08-18-2010, 06:20 PM
JDScherz's Avatar
Well I believe I only saw one washer, between spring and clip on stem is this correct?
Old 08-18-2010, 08:28 PM
built408's Avatar
Yes, that's correct.
Were any of the sealing rings damaged when they came out?
Old 08-18-2010, 08:38 PM
JDScherz's Avatar
Thats tomorrows adventure...do it all over again. Maybe 4th gear servo ring damaged??
Old 08-18-2010, 09:32 PM
Tootall's Avatar
there's a small spring that is between the case and the 2nd gear servo. It goes around the pin . . . did you put that back in ?
Oobray
06-13-2022 03:38 AM
pittman
01-19-2016 07:06 AM
1slwgto
08-16-2015 06:40 PM
fcompean
07-15-2015 09:55 PM
ferrellrooster
07-13-2015 09:53 AM
Quick Reply: Won't shift to 4th after Vette Servo install
