Will JB Weld fix this?
Old Feb 9, 2010 | 09:12 PM
  #21
Atomic's Avatar
I have a gauge for that
Interesting. How hard is replacing an output shaft?
Old Feb 9, 2010 | 09:15 PM
  #22
kbracing96's Avatar
It's not that hard to do once you do it a time or two. But you have to take all the guts out of the trans to do it. I would just clean up those splines with a file and run it.
  #23
gao8302's Avatar
On the trans or transfer case? transfer case is pretty easy. Do a search on here and you will find a write up on it. Cant remember who it was that did it.
The trans is a bitch. No idea how to do it
Old Feb 9, 2010 | 09:17 PM
  #24
Atomic's Avatar
Anyone have an info on the coupler thing? I cant find anything similiar and I thought it was part of the trans anyhow...
Old Feb 9, 2010 | 09:19 PM
  #25
gao8302's Avatar
Its just a spacer that connects the two together. Two seals and your done. i took my trans case of there once...bitch to get it back together and seal again.
Old Feb 9, 2010 | 09:30 PM
  #26
kbracing96's Avatar
You can probable just get a new coupler, new drive shaft, clean up the splines with a file, put it all back together and be just fine. That's what I would do. Just look over the out put part of the T-case for any cracks and you should be fine.
Old Feb 9, 2010 | 09:34 PM
  #27
Atomic's Avatar
I cant find any info for an adapter...
I have manual floor-shift 4wd so I have the np231 transfer case, right?
Old Feb 9, 2010 | 09:40 PM
  #28
sharpshooter's Avatar
https://www.performancetrucks.net/fo...=436007&page=2
Old Feb 9, 2010 | 09:49 PM
  #29
kbracing96's Avatar
^^^^ Yep, that's it
Old Feb 9, 2010 | 09:55 PM
  #30
Atomic's Avatar
That looks like it. What is the technical name for it or a part number or something? I've been looking for 30 minutes and cant find anything anywhere.
Edit1: Ah, finally, the part number is 15067970. Im hoping I can get one before the weekend. Looks to be only a $50 part.
Edit2: I was logging at the time and happend to have TC slip as a parameter. When it seperated my slip went to -1700rpm
