Will JB Weld fix this?
Old Feb 9, 2010 | 07:05 PM
Atomic's Avatar
I have a gauge for that
Default Will JB Weld fix this?
This is what happens when a ujoint lets go at high speed...
Old Feb 9, 2010 | 07:07 PM
Atomic's Avatar
I havent crawled back under to take a look since im so pissed right now, especially since ive had a stronger spicer ujoint for about a month now
Did the tailhousing on the trans shear off or what? Any guesses what im looking at?
Old Feb 9, 2010 | 07:10 PM
ChevyTruck's Avatar
something else
Holy crap that sucks!! I hope you are okay besides being pissed off.
Old Feb 9, 2010 | 07:12 PM
phasemaster1's Avatar
Thats what it looks like. Any Idea what the teeth look like inside where the shaft goes in? You must have **** when that let loose going that fast!
Old Feb 9, 2010 | 07:14 PM
ChevyTruck's Avatar
something else
I may look like the spins on the transmission output shaft may be gridded down too...
Old Feb 9, 2010 | 07:15 PM
00ChevyScott's Avatar
Wearin' da big hat
I would get the transmission completely rebuilt. Anytime a shock of that magnitude is sent through the drivetrain, you can be pretty certain that something else internal is damaged.
Old Feb 9, 2010 | 07:17 PM
Atomic's Avatar
I had just merged onto the interstate and gave it some gas then a loud hum then a second later a lot of clanging and smoke (im guessing the fluid hitting the exhaust) and pulled over to the shoulder not half a mile from the on ramp. Engine and rear are fine, just driveshaft, tcase, and trans are the unknowns.
Any bets on the torque converter? Its a vig triple disc which I was planning to keep when I upgraded the trans.
I wonder if the guy that rebuilt it will warranty it....
Old Feb 9, 2010 | 07:21 PM
Wearin' da big hat
As long as the converter hub is not broken, it should be fine. Just make sure you take it somewhere to be opened up and cleaned out.
Old Feb 9, 2010 | 07:35 PM
dlt76028's Avatar
I feel you pain man, ruined my trans the same way.
Old Feb 9, 2010 | 07:56 PM
Atomic's Avatar
The driveshaft looks fine aside from the ujoint of course. The Tcase was literally just sitting on top of the skid plate wedged in place by the two driveshafts. The output shaft of the trans is scored pretty good.
Damn.
