Will an FLT or PerformaBuilt 60/65E hold?
Old Aug 29, 2007 | 05:51 PM
tarinitup's Avatar
9 Second Truck Club
My Flt held up great for 1 year of spraying with a window switch. It started acting the first time I sprayed through the shifts. It was a 150 shot 402.
Old Aug 29, 2007 | 06:46 PM
2004SSS's Avatar
my trans handled the power i put at it for a while, and after a year of countless runs the converter finally broke so as long as you have a good converter i think you should be ok for a while. when i pulled my trans apart it looks good for the abuse it had .
running an 11.9 on 22's and weight of over 5300 lbs, id say thats at least 500-600 at the wheels.
Old Aug 29, 2007 | 07:31 PM
ZR1 DREAMING's Avatar
Good deal, thanks guys. I guess I'll go easy on the juice until I'm ready for an 80E or built T56 swap.
Old Aug 29, 2007 | 08:48 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Originally Posted by Z06 DREAMING
I asked to see who is running a high power combo while maintaing the 65E so I can find out how they are holding up. I never said I was dead set against it, just that I didn't want to go through the hassle. So I don't know what that statement was about.
That's what I was figuring. PerformaBuilt says they'll have a level 4 65E coming out in the next couple of months. No indication of the power capability that'll handle that I am aware of yet though.
Every time somene said something in favor of the 80e you had an excuse why you didnt want to do it thats why to me it read you were against it. IMO do the 80e now and be done with it. Remember many people are running 600+rwhp through stock or shift kit 80es. I have 750 into my trans, 200 for the sihft kit installed(including the kit), 250 in driveshaft changes, 150 for the wiring harnes, 180 for the input gear conversion for the t-case(which will work for yours too), 100 for the crossmember modification, reuse your stock dipstick tube, my trans came with the stock converter and flywheel which already had the spacer so I used it, and you will need to do something with the trans lines. You could do like Ben and have better lines and fix the length issue of swapping to an 80e. So with all that done you are still below the price of a fully built 65e and its stronger. You cant deny the strength and you know when you get it up and running the urge will be too strong to up the shot. Do what you will with the info I have given you but in the end you are going to have to go to an 80e anyway might as well do it now IMO.
Old Aug 30, 2007 | 09:38 AM
you were only th 2nd person to mention 80E.
Anyway...
Good info thanks. That's not that much you have in yours... I calculated up a bit more for me to do the swap. I guess I'll shop around a little more.
Old Aug 30, 2007 | 09:55 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Hey J,
I ran at those power levels and am the reason why Chuck decided on the 500hp limit.
During the time we were experimenting with the 65 and big power, I ran two essentially (had 3 but one was taken out in the first week due to manufacturing defect in the converter / install error). Of the next two, they performed very well, but what we learned is simply this: the reliability is shot to hell. I don't mean the reliability of what Chuck and Vince can build up -- those parts never had an issue in my trannies -- it was the other stuff -- the sprag was the last one and it broke while the truck was in de-tuned DD mode, and with no power being applied (literally sitting at a stop sign 1/2 a block from my house).
[edit: even so -- Chuck told me to continue to run the 65E I should plan on letting him refresh it once per year]
I did run 0 TM, but don't believe that was a contributor as my tranny failures were not to the performance parts. I ran detuned a lot (no biggie here, don't need 750 awhp to drive 5 miles to work in 35mph zones lol, but a hassle none-the-less). I had to constantly watch the tranny temps, and in the summer they were a concern almost everyday. We kept it under 200* when possible (sometimes sitting in traffic, that wasn't possible, and resulted in the first real failure). I was running a big tranny cooler and efans.
Basically what I'm saying here is this: You've got a few choices: 1) run 700hp and roll the dice every single day to see what random **** might take out your tranny and converter, 2) bite the bullet and put in an 80, or 3) detune your expectations and stay below 550ish (which is still going to push the reliability issue).
My advice if money is getting in the way, get a junk yard 80E (go talk to Mater about a low mileage one) and put in a shift kit, do your installs, run it til it breaks, let Chuck rebuild it.
Old Aug 30, 2007 | 10:09 AM
Originally Posted by TurboBerserker
Hey J,
Yeah that's what I'm affraid of... driving around everyday wondering when and where it's going to let go. LOL
I really don't want to drop $3k on another FLT just to turn around and have to go 80E. I guess I have another project to add to my list
Old Sep 1, 2007 | 10:48 AM
Breeze's Avatar
11 Second Truck Club
I just got back home after a lil trip in the truck and lost D in my level 5 65e I dont know whats wrong yet but feel as if this tranny is on its way out and should have just went with the 80e from the get go so now I get to do it all over again
Old Sep 1, 2007 | 12:49 PM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
breeze... talk to flt about loss of forward gears in drive. might be something simple.
z06... with your truck's weight, i'd definitely be lookin at an 80e swap.
Old Sep 1, 2007 | 01:21 PM
Breeze's Avatar
Yeah sounds like the 3-4 clucth has gone out on me.
SS94S10
Jan 3, 2019 01:57 PM
trxmxzx
Sep 29, 2015 07:42 AM
Chevy305
Sep 28, 2015 09:21 PM
01silvy
Sep 26, 2015 10:20 PM
trxmxzx
Sep 24, 2015 09:29 PM
