will a 97 model 4L80E fit my 2002?
Yes
The LSX bolt pattern didn't show up until 99' i believe, but the earlier models will fit. You'll have to leave out the top bellhousing bolt, since it's not there on the older trans.
I put a 96 L80 behind the LS1 in my truck. Used the stock 5.3L crank, the 6.0L/L80 flexplate, crank spacer, and standard L80 converter.
Bolted up fine
Bolted up fine
Valvebody changes from what i understand, and they moved to centerlube after 96. centerlube has one cooler line closer to the middle/back of the trans. I had mine build w/ the newer valvebody.
wiring is the same, old to new 80's.
You don't need the jumper harness. There are 2 unused wires going from a 60 to an 80, use those for the input speed sensor. Move a couple at the trans, and a couple at the PCM.
You will need to have it flashed to the 80.
You have more details on the wiring part without using a jumper ?
FlowmasterMufflers
Aug 14, 2015 01:04 PM
tgui
Aug 11, 2015 08:30 AM
bsgiffor
Jul 19, 2015 11:14 AM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
FlowmasterMufflers
Jul 9, 2015 11:35 AM
