Will 15" wheels Fit
Old Mar 28, 2005 | 04:00 PM
CF7GO's Avatar
Default Will 15" wheels Fit
I want to put 15" wheels on my truck! For MT ET Streets. Will they fit? Do I just have to grind off the calipers? There is just so many more options for 15inch tires. Also what size should I run? I have the 4L80E, 4.11s, and an Eaton. Thanks for the help!
Old Mar 30, 2005 | 12:17 PM
CF7GO's Avatar
Anybody try this?
Old Mar 30, 2005 | 12:36 PM
SBChevrolet's Avatar
I have heard you have to grind the callipers... but since your only puttin them on the back it might not be so bad grinding them is no big deal though...
Old Mar 30, 2005 | 12:51 PM
FILE's Avatar
Yes, they will fit but you have to grind the caliper. I have seen it done.
Old Mar 31, 2005 | 08:30 AM
04BlackGmc's Avatar
10 Second Club
yep a 4x4 guy did it by grinding the calipers and a spacer.
Old Mar 31, 2005 | 11:42 PM
OUT2WIN's Avatar
There are about 3 or 4 trucks running around here with 15" slicks on them we just grind the caliper, put the wheel on and see where it is rubbing and then grind it some more.
Old Apr 1, 2005 | 07:01 AM
FILE's Avatar
I was connsidering this since there so many choices with the 15' rim. Any drivability issues after grinding the rear caliper?
Old Apr 1, 2005 | 02:25 PM
vanillagorilla's Avatar
Are we talking aluminum or steel wheels here? I'm pretty sure a 15" steelie will fit with no grinding at all.
Old Apr 1, 2005 | 07:50 PM
OUT2WIN's Avatar
I never heard of any issues after grinding them down.
Old Apr 1, 2005 | 10:58 PM
WillPewter2000's Avatar
Have a buddy that ground his down no prob.
