Why are 5 pinion planets such a high price upgrade?
Old Mar 27, 2011 | 08:55 AM
fastnblu's Avatar
Originally Posted by RibeiroBJJ
Mainly its because any reputable builder will only use GM planets...And they are very pricey from them as with most semi complex oem parts. The "5 pinion" planetary gears you saw for cheap are not oem and are most likely modified 4 pinions...which dont hold up well...I bought a new (not rebuilt) aftermarket 5 pinion planet, and it was missind a few lubricating grooves that are machined from the factory ( held up to my 325 hp 350 tbi) ......Good parts cost$$$$$$
Agreed, when I had a 60E built years ago, builder wanted $600 for OEM 5 pinions. Forgot if that was front & back tho. It was awhile ago, as in 2 blown built 60E's.
Stick w/. OEM 5 pin.
Originally Posted by Beatdown Z
... From what I've read, aftermarket(China) 5-pinion planetary gears are weaker than GM 4-pinion planetary's.
That should tell ya everything ya need to know.
Originally Posted by Jordan927
yup, you'll likely pop a diff or u-joint before you pop the trans...
Can't say I agree. I say tranny goes 1st. They have for me; & I believe others blow more 60E's than G80's.
But u also never said stock or modded. The closest to the shock (ENGINE) gets the brunt of the abuse = tranny. It then transmits shock rearward. If u have sticky tires / slicks, that leads to more shock to rearend. Hard lauches don't do any favors to any driveline parts tho.
Old Mar 27, 2011 | 03:00 PM
Jordan927's Avatar
On a lifted truck with large tires...its almost always the diff that gives out first in my experiences. And if the trans does go, its usually on the output side...Its just a massive amount of mass to get spinning.
Old Mar 27, 2011 | 03:34 PM
Country Boy's Avatar
Senior Member
Also depends on the rear gearing. I run 4.88s and soon to be 5.13s.
I found a pretty reputable trans builder that will build a nice "level 5" with delco 5 pinions and such for a damn good price and will be going that route. Itll run the same price at Performabuilts level 2 (which I was dead set on). Im going to skip the billet shafts since I dont launch or anything. Its just a driver.
Ammadien
Jul 22, 2015 08:50 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
maxspeed05V
Jul 19, 2015 07:08 PM
JordanH
Jul 14, 2015 03:46 PM
Aboss
Jul 9, 2015 10:28 AM
