Who bulds the best 4L80E?
Old Aug 15, 2014 | 09:42 AM
Jake's Performance's Avatar
FormerVendor
I recommend Jake's
Rossler and Gilbert are both good builders but as someone said, I doubt anybody else in the performance industry is building as many 4L80E's as we do.
We build 8 4L80E's a week average, and almost all of these are going to 800+ HP combos.
I will also mention, that if you have a good local builder who is familiar with performance builds, that can be a good choice as well.
Old Aug 15, 2014 | 10:14 AM
Atomic's Avatar
I have a gauge for that
This may not be the right place to ask, but whats your opinion on running a hydraulic fluid (like hy-gard) instead of trans fluid for more race oriented applications? I know it usually handles heat better and tightens up a converter, but I mean in terms of clutch wear compared to normal dex3.
Old Aug 15, 2014 | 10:36 AM
BlackGMC's Avatar
Resident Retard
Originally Posted by smokeshow
Well lets be honest here, you've never gone full throttle in your truck, so the trans could fall apart at any moment
Which is true. I do have over 50k on the trans so something is working right.
Old Aug 15, 2014 | 11:03 AM
FormerVendor
I recommend the Hy-Gard type fluid for turbo combos that will see extended spool time.
Here's a set of clutches out of a Th400 used in a bottom 8 second car using Hy-Gard that had 2 years of run time on the street and strip with hundreds of passes. We freshened the trans, made some changes to the valve body, lightened up some parts, and it's now running 7's.
Here's the car.
Old Aug 15, 2014 | 11:11 AM
Atomic's Avatar
And the only modification needed to the trans is a filter with a wire element so it wont collapse, right? Can a th400 filter be used on an 80e? Thanks
Old Aug 15, 2014 | 12:22 PM
FormerVendor
Use the stock 4L80E filter, the 400 filter won't work and you have to use a brass screen 400 (Allison) filter.
Use the low viscosity version of Hy-gard unless you are trying to tighten the converter.
Old Aug 15, 2014 | 12:25 PM
oakley6575's Avatar
Is Hy-gard the John Deer oil?
Old Aug 15, 2014 | 12:31 PM
FormerVendor
Yes,
but it doesn't have to be John Deere brand. Mobil 424, Case, Caterpillar, and generic fluids seem to work fine.
Universal tractor/transmission hydraulic oil.
It seems to hold up better than synthetic and cost less.
Old Aug 15, 2014 | 12:34 PM
Atomic's Avatar
So for the 80e I do need a brass filter or will the stock filter suffice with either version of hy-gard? Just trying to clarify. I have heard hy-gard will collapse the stock filter and just want to be sure thats not true. I will probably mix 50/50 hygard and dex3. Thanks for your input
Old Aug 15, 2014 | 02:16 PM
TIM Z's Avatar
11 sec. Truck Mod
Same stuff I buy for John deere 2320 , a 5 gal bucket from rural king is like 25$
