Whats the difference; McGaughys spindles
Old Jul 27, 2007 | 04:58 PM
Neverdone's Avatar
Default Whats the difference; McGaughys spindles
Whats the differences exactly between the 2" lowering spindle for 17" wheels(P/N)2003T and the 2" lowering spindle for 16" wheels(P/N)2000C?
Is one prefered over the other?
From what I have read McGaughys is the spindle of choice no?
Old Jul 28, 2007 | 03:43 PM
Neverdone's Avatar
Hello? *tap tap tap* Is this thing on?
Old Jul 28, 2007 | 04:08 PM
GTOsRamairSilverado's Avatar
the only difference is that one will work if you have 16" wheels and the other will work if you have 17" or larger wheels.
i heard that they are good spindles but ive also heard that the belltech spindles are better.
Old Jul 28, 2007 | 06:22 PM
xlcooplx's Avatar
NOTE:McGaughy's makes two different spindles. There is a 16"+ spindle that will work on all wheels 16" and larger. However, these 16"+ spindles will decrease your turning radius. The better of the option would be to run their 17"+ spindles. These spindles can be used on all wheels 17" and larger. Also note, if you are running 17" wheels, you'll have to grind down the stud on your balljoint directly below the nut & cotter pin on it. Although this doesn't sound ideal, these spindles retain a factory-like ride and also keep the stock turning radius. Belltech also makes spindles. Their first design was junk from what I recall; however, they did revise the design and I believe the new design is a good design.
http://www.gmfullsize.com/forum/showthread.php?t=74532
Old Jul 29, 2007 | 01:12 PM
Neverdone's Avatar
GTOsRamair, thanks for repeating what I said.. lol
xlcooplx, thats exactly what I needed to know, thanks!
Old Jul 29, 2007 | 03:40 PM
well you asked !!!!!!
twake_410
Apr 14, 2016 09:58 PM
wickedRCSB
Oct 30, 2015 09:45 PM
Staggered 02
Oct 9, 2015 05:19 PM
gmcyukon
Oct 5, 2015 06:20 AM
sTNT971
Sep 26, 2015 06:27 AM
