What would be the top speed of a 4l80e with 4.88s and 31" wheels?
What exactly would my top speed be since now I'm runing a 4l80e with stock stall and 4.88 gears with a 30.4" dia wheel. 265/50/20s. 2wd. The engine is a lq9 6 liter with long tubes and intake. Ory 3" cat. Just got rid of my 4k stall converter. So I'm awaiting better mpg.
148.3 @ 6000rpm
150.8 @ 6100
153.3 @ 6200
155.7 @ 6300
158.2 @ 6400
160.7 @ 6500rpm
These are rough numbers if you were in 4th gear without converter slip and if you actually had the power to pull OD and a strong enough converter to handle that. Pushing those speeds in OD is asking allot.
150.8 @ 6100
153.3 @ 6200
155.7 @ 6300
158.2 @ 6400
160.7 @ 6500rpm
Follow this link and download the file and you can play with tire size, ratio etc.
https://www.performancetrucks.net/fo...0-4l80-396210/
zaathur151
Jul 6, 2015 10:57 PM
