What transmission is this?
i swear its only a 30 spline out put shaft after i took off the transfer case (it was a very long day but Ill go count again tomorrow) pic posted is the sticker on the side of the trans help please?!
I need to find measurements that are known to be correct, I haven't found two overall measurements to be the same .would like to know length with or without bellhousing 4wd unit
im getting right about 47" from bellhousing to end of transfer case in an 08' AWD Denali. i say "about" because it was the closest i could get measuring around stuff. I measure the transfer case as "about" 23.5" so that makes the transmission "about" 23.5" as well.
This came off of a TBSS forum:
AWD/4WD Transmission-bellhousing to end of output shaft (bellhousing to end of case)
4L70: 26.875" (22.25")
6L80: 27.125" [+.250"] (23.3")
6L90: 28.625" [+1.750"] (24.7")
4L80: 29" [2.125"] (26")
with a 29 spline output shaft??? NEVER seen a 90 with the smaller output shaft. Didn't know they made a 2500HD AWD setup either... Somebody was throwing stuff together that week.
