What servos are you using?
Old Jan 23, 2011 | 10:44 PM
KleenHall's Avatar
i have TCI supers 2nd and 4th, no issues, factory trans at 130k
and i used to use tow/haul a lot with manual shifting, before the motor and tune
Old Jan 23, 2011 | 10:58 PM
bigtodd's Avatar
im going to be doing a servo swap to my truck here pretty soon can i run the 4th apply from the vettes? and can run a .500 boost valve or leave the valve out? im going to be playing around with efi live on the truck to adjust some stuff also.
Old Jan 24, 2011 | 12:01 AM
TX Tahoe Z71's Avatar
Posting from my iPhone, but order vette servo and sonnax od servo. Done.
Old Jan 24, 2011 | 12:21 AM
MAG1C's Avatar
vette servo all the way billet servo feel l like in a car with some one that doesnt know how to drive stick and also known to break trannys vette gives you that nice crisp feeling there other will get on your nervs if its a dd
Old Jan 24, 2011 | 12:37 AM
meangreenburban's Avatar
Originally Posted by Red Truck
just a little info about my servo and situation in my truck.
The truck had 100k miles when i started modifying it. (about the same time people start having tranny problems)
I did the 224 228 cam, mod air box, ported throttle body, no cats, magnaflow muffs, ls1 e fans, 160 t stat, 4.10 gears and posi, tuned and 100 shot of nitrous. EVERYONE said that i was going to break the tranny if i sprayed thru the shifts. So i did some research on people breaking 4l60e trannys and as i learned more, it seems very few actually break hard parts in the tranny...Most just burn it up.
My theory is that these trannys burn up from not enough positive shift. GM wants it to feel smooth and not noticeable when shifting. So when applying any power or load to the tranny, it will slip into gear and the more slip the more heat and the more heat the more burnt clutches. Once you burn a clutch its is much easier to burn the next time.
So with all of my mods, i just put in the billet servo (stock 4th) with no spring. That was 10,000 miles ago....A stack of timeslips, uncountable street races, 70+ nitrous bottles ago.......My tranny is 100% stock other than the servo. It does shift very hard. And normally barks the tires going into 2nd with any applied throttle. BUT i dont mind the hard shift and i definately like keeping the money for the tranny swap in my pocket for now. Even if it did break tomorrow, it was definately worth the 50 bucks for a servo.
I haul heat and air equipment with this truck, i use it every day, i have taken road trips in it, and no problems so far....(finding something wood to knock on)
solid theory and very true. I got my truck @129K miles, original 4L60E transmission in a 6K lb Suburban. First thing I did was a shift kit and Vette servo, and it has held that trans together great, now at 151K miles.
Long story short, it comes down to your power goals. A vette servo is good for many applications but if you go big, billet is it. That's why builders use them in higher spec transmissions.
Old Jan 24, 2011 | 07:33 AM
pkozera's Avatar
After some more reading going to use the vette 1-2-2-3 so the shift is quick and crisp and not so harsh and use the billet 4th apply and cover for less in and out of od.
Old Jan 24, 2011 | 08:33 AM
1989k1500's Avatar
I had the Superior Super Servos(4th apply, cover, and 2nd) for my white truck, and I already have them for my Burgundy truck when I put the 60e in it.
Ever truck Ive ridden in with a vette servo I didnt like the way it shifted. And my burgundy truck has one currently and Im not going to reuse it.
Old Jan 24, 2011 | 09:42 AM
Preston129's Avatar
Vette servo from Circle D in mine. I like it, but when I start making enough power that it's not holding well enough any more I'll switch to billet.
Old Jan 24, 2011 | 08:34 PM
pkozera's Avatar
Picked them up today will be installed tomorrow. Sweet.
Wolftrk99
Dec 3, 2015 08:12 PM
Tigger Welder
Oct 1, 2015 08:41 AM
LARRY01Z28
28
Sep 28, 2015 07:54 AM
Tigger Welder
Sep 2, 2015 08:17 AM
lycominghunter
Aug 15, 2015 12:26 PM
