What rear gear for my turbo truck
Old Sep 6, 2020 | 12:44 PM
Jseal52's Avatar
Default What rear gear for my turbo truck
What rear gear would work the best with my truck.
5.3 72mm turbo 3000 stall and 4l60e. Rcsb 2wd truck.
right now I believe the truck has a 3.73 rear gear.
Old Sep 6, 2020 | 02:44 PM
ZO6Ted's Avatar
I had 4l60 and 3.42's with 275x20's. Changed to 4.10's and knocked off .64 in the 1/8th. My tires were tall though at 32". You should use an online calculator to see what you want to trap in the 1/4 in 3rd gear. Wallace Racing-Drag Racing Pontiac powered Firebirds,Trans Ams and Dragsters Don't be afraid of gear if you are still happy on the highway.
Old Sep 6, 2020 | 06:34 PM
darkirish63's Avatar
Better worry about that 60e first...you're gonna kill that thing quick.
Old Sep 6, 2020 | 06:48 PM
Jseal52's Avatar
I’m not to worried About the trans. It’s a fully built 4l60e and haven’t had a problem with it. Put a big trans cooler and make sure it doesn’t get hot.
Old Sep 6, 2020 | 08:37 PM
I've had two "fully built" 60es go **** up under hard driving conditions.. only a matter of time but, don't take my word for it...search the threads for countless others who've chased the built 60e. It's not the heat that'll kill it but the weaker internals that are available for it. JMTC
Old Sep 6, 2020 | 10:25 PM
terravast4's Avatar
Old Sep 7, 2020 | 09:14 AM
madmann26's Avatar
Unless you’ve got some secret sauce recipe that no one has ever heard of, save yourself some coin and heartache and swap it when it fails, and it will fail.
Old Sep 9, 2020 | 08:45 AM
zz454Chevelle67's Avatar
I killed 6 "built" 4L60's before I swapped. For me not swapping in the beginning was a very costly mistake. Good luck.
Old Sep 9, 2020 | 10:12 AM
ZO6Ted's Avatar
This turned into a transmission thread lol.
Old Sep 9, 2020 | 11:14 AM
arthursc2's Avatar
It always does 😂
its relevant tho because if the OP goes from 60 to 80 it may change his selection of gear
Turbos like load, so I'd be inclined to stay with what you got. Why are you looking to regear?
