what do i need 80e?
Old Mar 2, 2006 | 02:21 PM
seeyaa's Avatar
Default what do i need 80e?
I need to know what i need so that i can order my trans from speedE. i can make the crossmember i know i need the wiring harness,coveter cover,the shafts will be done at a local shop. but do need the flywheel or the spacer or both.do need the trans with the new tail shaft or the transfercase. sorry for all the ? but did some searches but could not find a clear ansewer.
Old Mar 2, 2006 | 05:04 PM
seeyaa's Avatar
help please
Old Mar 2, 2006 | 05:50 PM
Wilde Racing's Avatar
How do I change this text
You need,
Dip stick tube,
Cross member,
Cranck spacer,
Wiring adapter (including new harness for VSS)
4l80e,
Ether the biger inputshaft for transfer case, or the machined down out-put shaft. (There will be a write up very soon on replacing the transfercase input shaft.)
80e BIN. file for tune, (Give Nelson performance a call)
Front drive shaft,
Reardrive shaft,
Torque converter (DO SOME REASEARCH BEFORE YOU BUY)lol
Torque converter shield,
Cable bracked, (I did'nt buy this, I made my own) but for 5.99 at S.E, I'd just buy it. very hard to get trans cable perfict.
You might need the trans lines and fitting.
Old Mar 2, 2006 | 06:31 PM
SnakeOiler's Avatar
If speedE is Speed Engineering, then call them. I'm sure they can answer all you need to know.
Old Mar 2, 2006 | 06:37 PM
XLR8NSS's Avatar
Adkoonerstrator
Give Sean a call at Speed Engineering like Snake Oiler said. He will take care of ya.
Wrecker 426
Sep 30, 2015 09:39 PM
mitchellmade
Sep 27, 2015 08:27 PM
01silvy
Sep 26, 2015 10:20 PM
trxmxzx
Sep 24, 2015 09:29 PM
trxmxzx
Sep 23, 2015 09:15 PM
