what could it be????
Old Aug 21, 2009 | 08:32 PM
lablackbeast's Avatar
doesn't know what quit means
Default what could it be????
well my transmission wont shift from 2nd to 3rd at WOT and it will shift once in a while shifting i know my tranny aint messed up cause it drives normal on cruise what could it be??? also have a stall and tranny aint stock.........
Old Aug 21, 2009 | 08:57 PM
skeet's Avatar
tune ( maybe ) so youre saying it will shift just fine when cruising, but when going WOT it will shift from first to second and thats it?
Old Aug 21, 2009 | 09:15 PM
RandomHero's Avatar
Mine would do the same thing until finally it totally gave up. I had the work done by someone else, but I broke a piston of some sort(I believe an apply piston for the 3-4 clutch pack) and in the process burnt up my 3-4 clutch pack and quite a few of my other clutches.
Like I said, mine was the same way, It would shift fine at anything under 6000 rpm but it would slip a bit and eventually 4 montsh later it gave altogether.
Old Aug 21, 2009 | 09:28 PM
yea it will when just crusing then i floor it on d and it will go 1st to second then it wont shift to 3rd at all on d put when i shift it it will most of the time shifting
Old Aug 22, 2009 | 05:33 PM
anyone????
Old Aug 22, 2009 | 10:05 PM
performabuilt's Avatar
LS1TECH & Trucks Sponsor
It may just be a tuning issue, Have you made any mods recently power adders? Tires?
Old Aug 22, 2009 | 10:07 PM
00Silv4.8's Avatar
Im calling clutches burning or apply piston like RandomHero says. Get it rebuilt ASAP. my old 60 had issues shifting in to 2nd at WOT but never skipped a beat cruising. Never got it rebuilt personally so I donno what ended up being the issue.
