Well...here's my 80e
Old Apr 8, 2008 | 07:31 PM
dewmanshu's Avatar
Moderately Differentiated
Default Well...here's my 80e
First, before we get started...WTF is this oil leak. I got my head up in there and I can't see any leak from the heads. Antifreeze looks fine. Oil is just very used looking.
Sigh. I don't mind some dirty sheet, but jeeesh. Quit already. Wait till you see the trans in the next pics. Oil is all over it.
Old Apr 8, 2008 | 07:34 PM
dewmanshu's Avatar
No investigation yet, just a bunch of parts on the table. Forward clutches are melted together. Needle barrings appear intact in converter. Front part of housing bearing bottom is worn. That seems weird, would expect wear all over or spotty all over I guess. OD gears look stellar. LOL Keep in mind the black sludge you are about to see was COMPLETELY flushed out no more than 300 miles earlier. Three 1/4 mile runs on the new flush. Drive to track and back home and then to trans shop.
NoChrome's Avatar
where does your pcv stuff drain at?
Old Apr 8, 2008 | 07:36 PM
dewmanshu's Avatar
Suncoast...massive looking fugger...there is some discoloration on the snout, but looks normal to me cuz it didn't color all the way out. Seems like that's from the weld.
Old Apr 8, 2008 | 07:37 PM
dewmanshu's Avatar
Front bearing...
Old Apr 8, 2008 | 07:39 PM
dewmanshu's Avatar
WOW...never EVEN thought of that. I have it running over to a collector on the passenger side, but there is no reason to believe it is together. Could of came apart I guess. WOW. That would be AWESOME if that was the problem. sorta... I'll check that tomorrow! Thanks.
Old Apr 8, 2008 | 07:43 PM
dewmanshu's Avatar
Trans guy wasn't there, that was just me taking pics. He was out on a test drive. I only asked what some stuff was with his son. I asked him about the front bearing and he made this face...he said his dad saw that and ran straight to my truck and made sure the rear of the motor looked happy (as well as the front). He was the one that discovered my 65e's were losing pumps all the time due to a thrust bearing being out.
Old Apr 8, 2008 | 07:45 PM
NoChrome's Avatar
I do what I can.
Old Apr 8, 2008 | 09:04 PM
Grumpy5.3's Avatar
try your cam sensor o-ring, and the rear cover is bad about leaking. just the gasket though.
Old Apr 8, 2008 | 09:09 PM
dewmanshu's Avatar
wouldn't that spew oil all over the flywheel? or at least down in that area behind it. The oil is not on the back of the motor. Just the top in the rear.
