Weight distribution effect on front/rear suspension
#31
You have to understand the center of gravity in a vehicle and how moving the weight around effects that. I wish I could explain it better but I am far to tired and lazy to explain it. HaHa.
Which D-max are you referring to because the bars will be different in a regular cab long bed Vs. a Crew Cab ????
#32
High on diesel fumes
That's an indication that the rear shocks were too stiff. As I mentioned before and as George C just stated you need to get the front under control.
The limit Straps will definitely make it fell stiff in the front.
The Rattle/ Vibration could be anything. You need to identify where it is coming from first. Along with dampening the suspension, the shocks also isolate some of the road noise.
#33
The vibration is in the rear suspension, it's like a small quick oscillation that starts when I hit a bump. It's not a rattle or anything loose on the frame or anything like that. I'm struggling with how to describe it, shudder is the best word I can think of but it's still not a good one. It basically feels like when I hit a sharp but small bump, there are 2-3 other small bumps afterwards. I feel it through the seat. That's why I was thinking it was a stiff rear spring or shock, which is why I am confused about why it got worse with no shock at all.
#34
#36
The 2WD ext cab 06 Spring Special and the 05 VHO trucks in my possession both have labels on the bars.
LYT on the Left and RYT on the Right.
LYT 15072933
RYT 15072934
A quick Google search shows "CODE YT MAX TORQUE 7267"
I wonder how these would do in your truck?
LYT 15072933
RYT 15072934
#37
your springs are over worked right now just parked, they will transfer anything you hit.
have to try and see it as a scale sorta like a triple beam. you now have so much weight up front that no matter what it will offset the rear. since your current springs have all their energy being used trying to hold your truck up they have nothing left to help with any bumps. if you hit brakes they are struggling, if you hit a snail they struggle....
you added about 500lbs to front of truck and your front springs rate just arent up to task honestly, you need a way to control that weight and only way is proper spring rate. You will need a RCLB spring rate of a dmax truck....this will get you closest
a CCSB will have a different rate since truck has weight differently then a RCLB
its a balancing act that right now, instead of barely using energy your springs energy is being used to just to keep ya upright vs doing its job when hits bumps
#39
front is barely touching the bump stops yes. I don't think that's an issue though because that's how the factory design is, and the front is too soft right now if anything anyway. On the rear I am not touching the bump stops, I have about 4 to 5 inches of travel available.
I did some searching and it looks like I can pick up torsion bars really cheap from a couple of local scrap yards. Just have to decide which ones to get. I wish I could do the coilovers now, money wise it's just not a possibility at the moment.
#40
Did some quick calcs and I think I'm going to want something around the 7000 mark for max torque.
GG = 6707
GH = 7161
WZ = 7267
YT = 7267
Anyone know how to find out which trucks these bars came on? When I look at car-part.com they just list whether the truck was a 1500 or 2500, nothing more than that, and there are no codes on the listings.
GG = 6707
GH = 7161
WZ = 7267
YT = 7267
LMAO
