want to DROP
Old Aug 29, 2008 | 12:09 PM
95 bright teal's Avatar
i dont think so I believe the spindle is narrower to fit and that moves the steering closer to the hub making less turning
Old Aug 29, 2008 | 02:18 PM
Dezert1500's Avatar
I'm sorry, but every word in that post is wrong. Rumors still exist...no worries though.
I have Mcgaughy 16" drop spindles and lost NO turning radius. Best spindle to run only more work to install than your standard 17" drop spindle. The turning radius is lost from the balljoint bolts hitting the spindle when turning. This can easily be fixed with slight clearancing of the spindle. You don't sacrifice the strength of the spindle either. People with 16's be happy you have 16's, the 16"+ is a good spindle!
-Dezert1500
Old Sep 2, 2008 | 12:09 AM
I have never heard of the fix, i have read many threads on the issue and most people took them off, sorry
Old Sep 2, 2008 | 10:11 AM
Mark Johnson's Avatar
-Dezert1500
We talkin' about a 2 or 4wd truck? I don't have a problem cearancing the sindles some or grinding down a ball joint stud. I'm very interested in 16" drop spindles. Sorry if I'm beating this thing to death................
Old Sep 2, 2008 | 01:28 PM
Dezert1500's Avatar
You have 4wd so you can only use the Mcgaughy 17" and up spindle. Sorry didn't realize you had 4wd at first. I'll leave that info for others, since it good info and may help kill rumors.
Run a Mcgaughy 17" spindle, you may have to clearance the spindle some for turning. Not a big deal. You will have to use the Mcgaughy supplied shorter ball joint nut and cut some of the ball joint off. Not a big deal. PM me with any questions, I have dealt with these Chevy trucks for years they are easy to me.
Old Sep 2, 2008 | 01:50 PM
No way I can grind the spindle to fit a 16" wheel................
Edit; I know that's a big request.....
Old Sep 2, 2008 | 02:09 PM
Dezert1500's Avatar
No way, you need 17" wheels, it is very close. 17" stock wheels can be found on craigslist for $200 fyi.
Old Sep 2, 2008 | 02:14 PM
Thanks- guess there's absolutley no way around 17" wheels..................
USMCvet0311
Jan 16, 2016 06:04 PM
smok'nZ
Oct 6, 2015 01:14 PM
X_Racing1
Sep 30, 2015 01:59 AM
twake_410
Sep 25, 2015 10:09 PM
