Virbrations
Old Sep 8, 2010 | 09:14 PM
dusty4.8's Avatar
Default Virbrations
the truck will be the end of me i swear, i have a killer vibration at low speeds and high speeds doesnt smooth out untill around 80-85 then its smooth as silk. i racked it at work a few weeks ago found tie rod ends failing inner and outer replaced them all along with all new bushings in the uppers and lowers and realigned truck with hunter laser setup(i work for audi) but vibrations is all still there thinking it maybe in the axles ran it without brakes on the rack and noticed slight deformation on both sides side to side up and down while rotating at 25mph, rebalanced tires and wheels and tried my factory tires and wheels. anybody else having this problem
Old Sep 10, 2010 | 12:46 PM
bow tie guy's Avatar
I'd replace the steering rack bushings, sounds like you've
been through most of the "Slop" cures at this point ?
Old Sep 13, 2010 | 08:41 PM
dusty4.8's Avatar
nother question will broken spider gears cause vibration i just pulled rear cover to pull axles and check and spider gears are missing some teeth rear end has 70,000 since last rebuilt by dealer under warranty. also what year rear ends from when to when will fit under my truck 04 silverado 1500 sbss
