virbation at 65+
Old Mar 17, 2009 | 10:50 PM
vista4.8's Avatar
Default virbation at 65+
whole truck vibrates after 65 and i can move the drive shaft about 1/4 inch to each side near the carrier bearing, i doubt that's good. so new bearing? u-joints? help
Old Mar 18, 2009 | 01:22 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Start with tire balance, and ask the shop doing it to check the driveline u-joints and carrier bearing at the same time. The carrier bearing rubber mount has some "normal" movement in it. Most vibrations are tire/wheel related. Driveline speed vibrations usually are described as rumbling, since the spin 3-4 times faster than your axles.
Fepony
Nov 28, 2010 01:29 AM
Killtank
Mar 4, 2009 12:28 AM
silverbeast
Jul 4, 2008 01:58 AM
