vibration after 80mph
Old Nov 25, 2007 | 06:13 PM
v8
17,16,15,14,13,12,11 Drvr
ok the wood hit the rear side of the drive shaft, after driving it for a couple of days I went to get up on the freeway and noticed smoke coming from behind me, I let off thinking it was the motor and went wot again and it was comming from under the truck, so I pulled over and noticed trans fluid comming from tail shaft just thought it was rear seal at first then the brake light, abs light started to flash and then vibration got bad, pulled over and called wrecker, after getting it to dealer they told me drive shaft had a dent in it and tail housing bearing was shot, so they fixed the trans part and I had a drive shaft built, now the vibration is still there, so this brings me to believe the rearend is culpret.
but will take any advise I can get hahhaa
Old Nov 25, 2007 | 06:16 PM
v8
Originally Posted by 00Silv4.8
u sure the shaft is balanced right and all? maybe even u bent a rim or something hitting that wood if it fucked ur shaft. Maybe check balance on ur wheels 2? possible impact break on the inside wall?
well it could be like said earlier going to take it to rearend shop and let them look at it, if not then the tires will be rotated and ballanced at Discount tire, I can only hope the driveshaft company that built the driveshaft balanced it right. I'm at there mercy.
Old Nov 25, 2007 | 06:20 PM
00Silv4.8's Avatar
no joke but if they didnt do the job right in the first place its their fault. Just like if u were to bring it back to Discount after the vibration.. we are obligated to pull ur truck right in and do it over again. Pain in the *** but sure. Just hope alls well and u find out what it is and its not too expensive
Old Nov 25, 2007 | 06:53 PM
v8
your right about there work, there well know in houston for there work, thanks for the help everyone.
BCraven1018
37
Dec 20, 2016 11:46 AM
black00chev
Aug 28, 2015 03:39 AM
1bad2k
Aug 18, 2015 09:50 PM
vipergtrdj
Aug 6, 2015 10:19 PM
