vibration at 90-110+
Old Apr 12, 2010 | 10:38 PM
dlt76028's Avatar
Originally Posted by fastrt
yes fat end towards the front, but it moves the pinon up or give you more positive pinon. fat side in the back negitive pinon, and it will point down.
Negative. Fat end towards engine moves pinion down. Think about it, leaf springs don't move so putting a wedge between them and axle with fat part towards engine will push axle down.
Old Apr 12, 2010 | 10:54 PM
fastrt's Avatar
11 Second Truck Club
my bad I had my mind on flip kit spring under axle. your right....scratch what i said and reverse it.
Old Apr 15, 2010 | 09:45 PM
LS1TRUCKGUY's Avatar
i have 4* shims with the fat end facing the roll pan, which pushes the pinion down.(flip kit) i had a vibration between 80-100. the shims helped, but didnt solve the problem. im battling a few flip kit issues right now...
Old Apr 15, 2010 | 09:49 PM
did you have a nuetral (0*) pinion angle before you used the shims? if so, that will wear out the u-joint and also cause this... ask me how i know
Old Apr 15, 2010 | 11:22 PM
1Bear's Avatar
You may already be doing what I’m about to mention, but there are quite a few that don’t really understand the driveshaft angles and the proper approach at setting them. Make sure that when setting the pinion angle that the tail-shaft/driveshaft/pinion angles are measured against one another and to not set the pinion angle degrees vs the ground. I see what seems like entirely too many people that just grab an angle finder and try to achieve just a certain pinion angle in relationship to the world.
Old Apr 17, 2010 | 12:52 PM
fastrt's Avatar
well... yesterday i put it on the drive on lift at the shop, unloaded the caltracs and took these measurements down...front drive shaft slip yoke= -6*, drive shaft is -2*, and pinon angle at pinion yoke is -4*. the pinion is facing up, so I put s 2* shim fat end in front(s&h drop). it brought my pinon to -2*, I need 2* more to put my angle at 0* pinon, -4 driveshaft and -6 trans. I have 5* total shim now, i have found the 2* shims i used to be about .25* to .5* smaller than advretised. I think i will try a 6* shim and see how it works, but i will hae to find one. does this make sense?
Old Apr 17, 2010 | 12:56 PM
fastrt's Avatar
oh, and i tested it, and it didnt take the vibration away. but it comes in at 95 now.
Old Apr 17, 2010 | 01:47 PM
Daryn's Avatar
Formerly darynC-10/23/10
when i had my 4l70e i would have a vibration come in at about 100......it never really bothered me cause my truck only saw a max of 75-80 mph on the street .....
make sure your pinion is set at -2 , replace both your u joints, grease your slip yoke.. and you should check your tail shaft bushing
Old Apr 17, 2010 | 04:28 PM
fastrt's Avatar
I think the 6* shim will bring it back to -2*. u-joints are new spicer, drive shaft was balance by a truck driveline shop so I may have to find a high speed balance shop.
Old Apr 21, 2010 | 01:21 PM
fastrt's Avatar
ok **** it!!! I put the damn overload back in, its not worth the extra 1.5" drop. I have not tested the vibration yet, but it was not there before I took the overload out. oh and fyi there is not a 6* shim. 5* is the biggest they make.
