Vibration 80 mph plus
Old Nov 29, 2017 | 11:50 PM
chevyboi925's Avatar
Default Vibration 80 mph plus
Long story short I had my driveshaft rebuilt 6 months ago and after breaking a driveshaft. I haven't really pushed it to its limits and I think I've stayed under 70 mph ..well recently I went from A3/6 drop to A4/7 drop and then today I noticed going about 90 miles an hour a pretty bad vibration and it seems really noticeable 80 to 90 miles per hour going over that almost seems to go away not 100% sure.. checkes my pinion angle seems great . I even rebalanced my rear tires ...and on the way home from the shop same thing ...I did notice my Carrier bearing had a lot of play between the rubber and housing so thinking maybe that's it I was wondering anybody else's input also I can't even use GMs new improved bearing because I am using belltechs Carrier bearing lift relocation kit that does not use the 2 studs ..but the 2 holes in the housing wondering if anybody has A4/6 drop without using any type of Carrier bearing modification and is doing just fine?
Old Nov 30, 2017 | 07:19 AM
madmann26's Avatar
What does your pinion angle look like?
Old Nov 30, 2017 | 08:19 AM
Looks great diff is Parallel with the front shaft The front shaft sits at about 0゚ and the diff sits at 0゚
Old Nov 30, 2017 | 08:20 AM
Also 2006 silverado extended cab
Old Nov 30, 2017 | 09:23 AM
madmann26's Avatar
Start with the center support bearing. Replace it if it's loose.
It has to be pressed off/on.
Old Nov 30, 2017 | 09:27 AM
Yeah I think that's what I'm going to do I just ordered one
It's funny because belltech uses these 2 holes in the housing to re locatebut Chevy's new version of the part does not have those holes anymore so kind of annoying luckily I was able to find neapco bearing from dennys ds that is og design
Old Nov 30, 2017 | 09:56 AM
madmann26's Avatar
You can make your own relocation kit for about $12.
Old Nov 30, 2017 | 10:48 AM
Well obv i already have 1.. any pics to see if its a better design?
