vibration
Old Feb 4, 2010 | 10:14 PM
dusty4.8's Avatar
Default vibration
got a question. ive got an 04 silverado with 125,000 miles on it and it gets a vibration between 60 and 75 mph its a 5spd truck ive checked everything feels like its in the right rear almost ive tried new tires, rims, brakes have no clue anybody know what it may be
Old Feb 4, 2010 | 10:22 PM
2005 Silverado's Avatar
SPAM HUNTER
Could be an axle.
Old Feb 4, 2010 | 10:24 PM
dusty4.8's Avatar
i had the gear replaced at 85,000 axles were replaced then due to spider gear splitting the carrier and i havnt been to hard on it since only two trips to the track and i had the vibration before the track
Old Feb 4, 2010 | 10:32 PM
SPAM HUNTER
Factory blemish's are known, pull the brakes off and spin the axle and check it with a dial indicator.
Old Feb 4, 2010 | 10:35 PM
dusty4.8's Avatar
i check it out this weekend i guess its the only think it could be beside maybe the driveshaft balance
Old Feb 4, 2010 | 10:52 PM
budhayes3's Avatar
PT's Slowest Truck
How about pinion angle or U-Joints?
Old Feb 4, 2010 | 10:58 PM
JoeGibbSilverado's Avatar
vibrations suck!! i finally got rid of mine, and it was all improper wheel balancing, but i also have a tie rod end, it could be any of the following
1. wheel balancing
2.pinion angle and u joints (as suggested)
3. bent axle flange, or excessive runout
4.tie rod ends
5.wheel bearings failing, im sure theres more, but these where the top 5 suggested to me, good luck
BCraven1018
37
Dec 20, 2016 11:46 AM
black00chev
Aug 28, 2015 03:39 AM
1bad2k
Aug 18, 2015 09:50 PM
vipergtrdj
Aug 6, 2015 10:19 PM
