V6 springs
Old Feb 24, 2016 | 06:29 PM
Dangeruss5.3's Avatar
Default V6 springs
Hey guys. I have an 01 Silverado. I remember seeing people putting v6 springs on the front of their trucks. Is the spring rate better for weight transfer? If so how much does it drop the front end. Thanks for the help.
Old Feb 24, 2016 | 07:15 PM
George C....'s Avatar
Formerly ScreamingL
When i ran v6 i cut 1.25 coils for around 2" of drop, now i have JDM drag springs up front uncut and gave me about 3" of drop
Old Feb 24, 2016 | 07:19 PM
I have a 3/5 drop now. I have lowering control arms on it and a bell tech flip kit on the rear. I'm in the process of changing shocks. Qa1 r series up front and afco double adjustables for the rear. I was just wondering if changing the springs would have made a difference
Old Feb 24, 2016 | 07:24 PM
Formerly ScreamingL
Youll want a double adjustable up front if you can afford them
Stock v8 springs will still do job well
Make sure your suspensions is free moving
Old Feb 24, 2016 | 07:33 PM
UnVmy5.3's Avatar
George did you finally got the lightning springs to work? last time I was on your page you took them out because it was way to low
Old Feb 24, 2016 | 07:44 PM
I almost went with a double adjustable but I didn't because I didn't figure I needed to worry about compression. What would be the importance of a double adjustable on the front of a truck? I figured you would only need a double adjustable if you were pulling the front tires. Sorry for the newb question. Trying to learn. Thanks again for the help.
Old Feb 24, 2016 | 07:47 PM
Formerly ScreamingL
I removed my drop spindles but kept springs
Old Feb 24, 2016 | 07:49 PM
Formerly ScreamingL
Compression on front is very important...if front slams down to fast it will unsettle rear....fronts should be doubles and if had to cheap out then do so on rears
Old Feb 24, 2016 | 08:07 PM
Well since I already have everything I'll try it out. If I have to I'll switch to a da. Hopefully being the R series it will help out with unloading the rear tires.
Old Feb 24, 2016 | 08:15 PM
Formerly ScreamingL
Many ppl run singles and have good success...chances are youre not powerful enough to really worry
