using trans pressure port
Old Mar 9, 2009 | 09:28 AM
Jeteys5.3's Avatar
Default using trans pressure port
i know alot seem to use this for hooking up the sender to their trans gauge. But is there anything bad about it? as in, can it hurt the trans at all? just seems odd for some reason making me think it might not be a good idea. I just imaging the sender coming into contact with something inside....but i would like to hook up this trans temp gauge.
Old Mar 9, 2009 | 09:36 AM
nonnieselman's Avatar
thats how you hook it up..
you can get a "T" and put the sending unit on the outlet port of the trans cooling line if you want.
Old Mar 9, 2009 | 10:46 AM
Jeteys5.3's Avatar
i know thats how i "can" hook it up.....but is there any possibility of that causing damage to the trans?
Old Mar 9, 2009 | 10:49 AM
BIRCHZ71's Avatar
no no damage possibility. i have had my trans sender in there for a while then got a performabuilt trans and they told me to put it in there as well. they also advised me that putting the sender in the pressure port usually reads temps about 15-20* higher then it actually is, which i can attest to because i just put my escalade cluster in and it reads about 15* cooler than my pillar mounted trans temp gauge.
Old Mar 9, 2009 | 10:51 AM
lownslo's Avatar
How i have mine and its how nonnie has had his for several years! No problems other than output shafts and i dont think thats from the sender
Old Mar 9, 2009 | 11:08 AM
kbracing96's Avatar
It it was a "bad" place to put it, do you think people would be putting it there?
Old Mar 9, 2009 | 11:20 AM
budhayes3's Avatar
PT's Slowest Truck
Yea, I've heard that it's an easy solution, but not the most accurate place to get your temps from. I'd think that the best route would be to get a bung welded into the trans pan, but that's a little more costly and possibly time consuming.
Old Mar 9, 2009 | 12:36 PM
Jeteys5.3's Avatar
alright cool i will put it in there tomorrow then
thunder550
Oct 8, 2015 04:53 PM
Ferocity02
Jul 17, 2015 07:05 PM
GMCtrk
Jul 17, 2015 06:39 PM
ferrellrooster
Jul 17, 2015 07:07 AM
rojeho
Jul 12, 2015 06:10 PM
