upgrade to two piston rear
Old Nov 23, 2007 | 11:45 AM
seadoo's Avatar
Default upgrade to two piston rear
I have a 04 1500. I want to upgrade to a SSS or SUV 2 piston rear caliber with bracket and rotor. I also want to know if the SSS has a different front brake setup than the the 1500's as well. I am planing on doing the rear brake swap, different pads all the way around, and SS brake lines. I tow some heavy trailers that do not have brakes on them.
Old Nov 23, 2007 | 01:30 PM
xlr82sxs's Avatar
better off to do a big brake kit upgrade with hawk pads and the ss brake lines you're already planning on doing.. you'll be more pleased with it.
Old Nov 23, 2007 | 01:54 PM
seadoo's Avatar
I really dont want to upgrade to larger wheels though... thats the problem I have with doing a big brake kit.
Old Nov 23, 2007 | 02:32 PM
then upgrade to stainless braided instead of the rubbers, and some hawkpads, possible slotted rotors that should make a substantial difference, or even a hydroboost system if you wanter, Im not sure about the 2pistons if they do work or not, but I think brakes are the least of your problems pulling heavy *** trailers with a 1500 and a 4l60e imo
Old Nov 23, 2007 | 03:19 PM
seadoo's Avatar
it tows perfect, and the temps are about 180 or cooler unless climbing a big *** hill. the weight is about 6K tops most of the time
Old Nov 23, 2007 | 04:12 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
SSBC makes replacement calipers that have alot more clamping force then the stockers and you dont have to get larger wheels.
Old Nov 23, 2007 | 06:19 PM
TG02Z71's Avatar
Like these babies.
just go ssbcbrakes.you know what
Lots of diffrent options.
Steve-O-08
Apr 19, 2018 09:32 AM
SLOPONY
20
Oct 18, 2016 06:05 AM
DarkhorSe_SS
Aug 20, 2015 08:58 AM
lycominghunter
Aug 15, 2015 12:26 PM
black6spdz
Jul 16, 2015 01:32 AM
