U-Bolts Length For Rear Block Removal
Old 10-19-2017, 11:08 AM
ridered4life250's Avatar
Default U-Bolts Length For Rear Block Removal
I have a 2017 sierra and am going to be taking the blocks out of the back to get the truck a little more level. Does anyone know the length of the new u-bolts that I will need? Im not going to jerry-rig this so I want new u-bolts.
Old 10-19-2017, 11:15 AM
FFDP's Avatar
I believe if you look up u-bolts for like a 99-06 truck that is 2wd will be the shorter u-bolts from the factory.
I removed the blocks on my 2012 and just used 1 thick washer on each nut and still had room, didn't have to buy new bolts or anything.
Old 10-19-2017, 12:39 PM
1redta's Avatar
I put the blocks on top of the leaf spring and just tightened the stock u bolts been that way for 80,000 miles with no issues
Old 10-19-2017, 01:44 PM
Slowest turbo build ever!
black00chev's Avatar
On my truck, I went to either Auto Zone or Advanced Auto and bought a new u-bolt kit that had u-bolts that were threaded the whole way and then just cut them down to length after I put them on. Much less expensive than the factory u-bolts.
