Two piece drive shaft question
Old Jul 2, 2011 | 11:38 AM
Calbo's Avatar
Question Two piece drive shaft question
Does the two piece drive shaft in my truck have to go back together in exactly the same position at the carrier bearing for balance issues? I did not mark it when I took it apart and am wondering if I need to send it to a shop for balancing.
Old Jul 4, 2011 | 07:34 PM
Calbo's Avatar
Lightbulb
A buddy of mine pointed out that the slip joint only goes back together one way so there is no way to mess it up. Live and learn!
Old Jul 4, 2011 | 10:00 PM
SmokinHot98's Avatar
yep, there is a special tooth in there so it only lines up one way
Old Jul 4, 2011 | 10:23 PM
Gadgetized's Avatar
If it didn't line up only one way, it is important that it go back the same way. If there was a weight on it, and it was assembled 180 degrees off then it would be 2X out of balance as it was before it was even balanced. This is something very important to remember especially when changing a joint at the yoke.
Old Jul 4, 2011 | 10:26 PM
Chevyboy_erik's Avatar
Good info... Glad i saw this im replacing my carrier bearing tomorrow
pjb1972
Sep 17, 2015 02:06 PM
vmaxpro
Aug 4, 2015 07:02 AM
USMCvet0311
Aug 1, 2015 07:45 AM
Ketis
Jul 23, 2015 12:37 PM
