TurboNoma won't go into gear(drive)
Old Feb 20, 2007 | 09:55 PM
Turbonoma's Avatar
Originally Posted by James B.
If the torque converter was not seated all the way the pump will be destroyed but the converter itself is most likely fine, as long as it was the correct converter in the first place...
Boy I hope you're right! Guess it's time to get the good parts and rebuild it to take the abuse.How would I know if the tc is ok?
PEACE OUT>Tony
Old Feb 22, 2007 | 01:17 PM
Turbonoma's Avatar
Can anyone provide me with a list of parts and where to buy them to rebuild my tranny to support 500hp? PEACE OUT>Tony
Old Apr 5, 2007 | 05:42 PM
Turbonoma's Avatar
Default Trans rebuild time
I just about have the trans out. Found a local racer who can rebuild it to take whatever I can throw at it.PEACE OUT>Tony
http://i160.photobucket.com/albums/t193/turbonoma1998/DSC01590.jpg[/IMG]]
Old Apr 9, 2007 | 08:10 PM
Turbonoma's Avatar
How the hell do I remove the trans dipstick? Seems like they glued it in place. PEACE OUT>Tony
Old Apr 9, 2007 | 09:19 PM
Turbonoma's Avatar
Default Let the spending begin
New parts starting to come in. PEACE OUT>Tony
Old Apr 11, 2007 | 03:43 PM
Turbonoma's Avatar
Default RIP 4L60E trns
I'm having it rebuilt here by a local racer. He says he can put it together so it can take my extra hp. I got the trans down today. The converter seems to be ok, don't know about the trans thou. Here are some pic's. PEACE OUT>Tony
Old Apr 16, 2007 | 06:11 PM
LMK2005's Avatar
Man i feel your pain, i currently have the SAME problem, and i am going to finish pulling my trans out tonight. I just did my 6.0 swap and the thing started, i was so happy. Went to put the thing in gear, and nothing....Good luck to you, hopefully nothing will be broke. I'm praying for that with mine right now. Or else its going to be a very expensive lesson for me as well.
Old Apr 17, 2007 | 09:00 PM
Turbonoma's Avatar
You probably broke the pump just like I did. I'm taking the trans over to the builder tomorrow to see how much is the damage. Hopefully it may just be the pump. Here is a list of parts that I will use to beef up my trans. PEACE OUT>Tony
In addition to the pump.
Reinforced input drum w / cryo
4L70e reaction shaft with cryo
beast sun gear shell
Use bw high energy clutches. Cheaper than the blues and hold up to daily use much better and hold REALLY well.
Bonded pistons if you don't have them already.
Transgo HD2 kit for the 4l60e
Reinforced 4L70 sprag.
Billet 4th servo
Corvette servo
Raybestos powerband
That's all you should need. I know it doesn't sound like much but that's it.
One other thing. If you have troubles with weird shifting when you really start pushing it, you'll have to go with a modulator to replace the stock Pressure control solenoid.
Now. If you go over 500HP, you'll need a billet output shaft and input shaft. Keep it at 500-510HP.
You do NOT need 5 pinion planetaries.
Old Apr 18, 2007 | 10:04 AM
LMK2005's Avatar
I'm going to pick my trans back up in about an hour, i just bought a new pump rotor kit... I have not heard anything from the trans builder, so im guessing the pump is ok. I think the new pump rotor kit was like $30.
Old Apr 18, 2007 | 01:24 PM
Turbonoma's Avatar
Got the trans over to the builder today. Good news is the converter is ok but the pump is definately shot. I'll be ordering the parts I listed asap. PEACE OUT>Tony
