Trutrac Swap???
So from what I understand my buddy has a 93 z71 with a 8.5" 10 bolt and a Trutrac, in order to swap my G-80 (05 z71) with his trutrac so he can sell his truck, all I have to change is the bearings on both of them and then swap the ring gears over right?
Thanks
Ryan
Thanks
Ryan
IT WONT WORK!!!! The hub on his carrier is smaller than your hub. They make the conversion bearing for your carrier to fit iin his but not the conversion bearing for his to fit in yours.
NEGATIVE, there is no difference in the carrier ends, the only difference is the bearings. Get an 8.5 install kit to install it in the older truck and an 8.6 install kit to install it in the newer truck.
Yea I knew they would need to be set up and that I would need to have the bearings pressed on at a machine shop, it was just the spline count that everyone keeps telling me different answers on. Thanks for the input guys, Ill let you know how it goes.
So its looking like they are both 30 spline, are there auto parts stores in town that sell quality bearings and shims or should I just buy a master install kit for each?
