Truetrac in turns?
Originally Posted by DrX
Mine will squeal with any throttle on a tight 1st gear turn.
One thing I have heard about the TT's is that they used to have just 2 worm gears and due to breakage they upgraded to the 3 worm gears they have now.
Mine has survived several hard launches on slicks with a manual running mid 12's
Haven't checked the fluid level recently, but I will. No signs of leakage.
The gear guys actually recommended a locker but I wanted something with better street manners. They said the G80 was designed to keep the rear end of the truck from getting ahead of the front on wet/slippery surfaces. That's why it won't lock up once you are already rolling. After being used to the G80, I had a couple scares after the TT first went in. Now I switch to Auto 4WD whenever the roads are wet, just in case I forget about the TT in back.
My Eaton LSD squeals the inside tire in a parking lot even with no throttle... kindof funny... everybody always looks.. The Toyos i have squeal louder than any tire ive heard..
. Backing up a trailer, the inside wheel wants to skip to keep up with the outside wheel. Doesn't seem to be much differentiation happening.
My G80 does this same thing once in a while, It's obviosly Locked (totally) when it shouldn't be. I don't think your TT should be doing that. if so, you could have saved $$$$$$ and got a spool. I Plan on getting a TT, But if it does that then maybe I should get somthing else....
i never had an issue with my last true trac although it was in a dodge 9.25 rearend. i went with a locker this time just to be different. but i would never get a spool for a daily driver. i see people talking about getting a spool and thats great for the track but i cant see how that is enjoyable for a vehicle you drive everyday.
