TrueTrac gear oil - synthetic or no?
Old Jul 12, 2013 | 02:15 PM
KC_kid's Avatar
Default TrueTrac gear oil - synthetic or no?
Eaton product info says no synthetic but the installer and GM manual say synthetic. What to use? I was planning 80w90 in front and 75w90 in rear, no synthetics. Just got my 4.11s broke in with the new true Trac, changing gear oil Monday.
Old Jul 12, 2013 | 03:14 PM
KevinF56's Avatar
Use regular oil. No synthetic.
Old Jul 12, 2013 | 03:24 PM
DTHPROOF's Avatar
^Yep. I ordered mine from the man himself, Ron, and he told me to explicitly use conventional.
Old Jul 12, 2013 | 03:39 PM
KC_kid's Avatar
Thanks. I'll get the conventional. BTW, the driveability of this truck skyrocketed with the 4.11 gear and the 6speed trans. It's a shame I had to spend money on this mod and GM couldn't make it this way from the factory.
Old Jul 12, 2013 | 03:42 PM
Ferocity02's Avatar
You must use conventional. Some people have used synthetic and it caused the diff not to work properly. I used Valvoline 75W-90.
Old Jul 13, 2013 | 12:42 PM
craigsix's Avatar
i used redline synthetic with crc stalube posi lube in my stock g80 with 4.10 gears and it worked great.
Old Jul 13, 2013 | 12:43 PM
DTHPROOF's Avatar
The stock G80 and the TrueTrac are very different though buddy.
Old Jul 13, 2013 | 06:14 PM
pewterliftedz's Avatar
I use conventional 75w90 lucas on my tru trac. That's what my installer recommended.
Old Jul 16, 2013 | 04:09 PM
1994Vmax's Avatar
I have the Detroit Locker... not the Tru Trac but it also says conventional fluid only. I only run Amsoil 75w140 synthetic in it and it works just fine...
Old Jul 16, 2013 | 04:33 PM
black00chev's Avatar
Slowest turbo build ever!
The Detroit locker doesn't use any clutches or anything that can slip. The gears in the truetrac are designed to work based on friction, therefore they can not use synthetics due to decreased friction.
