truck vs car torque convertor
Old Mar 18, 2011 | 02:42 AM
Denali08's Avatar
Default truck vs car torque convertor
I have a new 3400 multi disc tc from F-body LS1 4L60E. I want to install it in my 2003 chevy silverado 4L65E.
Is it going to fit?
If not, what is the difference between truck and car TC. I had someone tell me it will but I want to double check with people who done it.
I don't want to remove my truck transmission beforing making sure it will fit because I am paying someone else to do it.
Old Mar 18, 2011 | 04:25 AM
LS1TRUCKGUY's Avatar
yes it will fit. no differences at all
Old Mar 18, 2011 | 05:38 AM
Denali08's Avatar
What size is stock TC on the truck?
The car TC that I have is a little small maybe 8.5". Any effect of smaller size TC on tranmission heat? I have stock trans cooler on my truck.
Old Mar 18, 2011 | 07:28 AM
JFOLM's Avatar
I would call the converter manufacturer and see what they think it would stall to behind your truck. It may stall a little lower. You may already know this though.
6789olds's Avatar
stock is 300mm 12 inches i believe
Old Mar 18, 2011 | 07:31 AM
Denali08's Avatar
I would be more than happy if it will stall at 2800-3000.
Old Mar 18, 2011 | 08:08 AM
JFOLM's Avatar
FWIW,
I have a converter that was said to stall to 4400 in a f body and PI said it would stall to around 3600 in my truck. I haven't used it yet. Just food for thought.
Old Mar 18, 2011 | 09:07 AM
Wilde Racing's Avatar
How do I change this text
Another issue to consider is the lock up clutch. I went through this with my art carr, if the converter was designed for a car, the clutches may not hold when trying to lock in a truck.
Old Mar 18, 2011 | 09:21 AM
Denali08's Avatar
Well, my truck is very light being stepside short bed weighing 4300Ibs.
TC came as part of 4L60E level 5 built by RPM Transmission for F-body that is supposed to be able to handle 600rwhp.
So, not sure if I should worry about the tc in my little truck.
Also, I checked Circle D and they list truck and Car LS1 TC with same part number.
Old Mar 18, 2011 | 01:09 PM
Circle-D's Avatar
Former Vendor
You guys are correct, converters are the same. But might stall a little different because of weight. And like mentioned, the lock up clutch might cause issues with towing and such....
Chris
