Truck lower on driverside?
Old Aug 6, 2008 | 07:38 PM
BKnBLK05's Avatar
Default Truck lower on driverside?
Hey guys my 05 with 26k on it is lower on driver side,just picked up today from dealership they changed the left front coil spring and the left rear leaf spring,and truck still lower on driverside,has anybody encounterd this problem, if so please share your knowledge...thanks in advance
Old Aug 6, 2008 | 07:44 PM
02BlueStepside's Avatar
Yes, its the chevy lean. All the trucks tend to sit lower on the drivers side, some noticable, some not.
I thought there was a spring spacer gm had that lifted the drivers front and ultimately leveled the truck. You could also use a lowering shackle set on the 1" hole on the passenger side of the truck. Only other option is to cut the passenger coil a little at a time until its level.
Old Aug 6, 2008 | 07:51 PM
blue2003ls's Avatar
Mine had it too. I just ended up cutting about a 1/4 of a coil out of the passenger side when I lowered it. It still rides nice and solved the lean problem.
Old Aug 6, 2008 | 08:15 PM
BKnBLK05's Avatar
Yea I'm gonna be putting my 3" shackles back on ,took'em off so they would'nt give me any s#$% about warranty work,But yea I think I'll offset'em when I reinstall 2" hole on driverside and 3" hole on passenger side...if that don't do it I'll cut the coil... thanks guys
Old Aug 6, 2008 | 09:16 PM
fossil's Avatar
11 Second Club
Gas tank, ABS module, battery, and driver all on the drivers side. Yes it will lean. New springs will help some, or some spacers.
Old Aug 7, 2008 | 12:00 AM
chevytruckguy's Avatar
You can either trim the high side coil, or add a spacer to the low side.
Old Aug 7, 2008 | 08:16 AM
454navyss's Avatar
eibach makes a bushing that goes above your drivers side front spring to fix the problem. it only costs about $40, i'll see if i can find the link for you.
Old Aug 7, 2008 | 08:49 AM
JB1's Avatar
JB1
Subject: Left Front of Vehicle Sits Low - keywords alignment appearance body fender spring suspension #PIT3281A - (12/13/2005)
Models: 1999-2006 Chevrolet Silverado
1999-2006 GMC Sierra
2 Wheel Drive Models Only
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Left front of vehicle sits low.
Recommendation/Instructions:
Measure front trim height keeping in mind that the trim height tolerance is .5" difference side to side. Verify that the vehicle is equipped with the correct production front springs. You should measure the standing height of both front springs to ensure that they are equal height. Check "z" height measurements as per SI. After determining that the above checks do not influence the concern, install a front spring upper insulator, P/N 15756770 in the lower control arm spring pocket. Install 1 insulator at a time and measure the change between installations. A maximum of 2 insulators per spring pocket may be used.
Please Note: The steering alignment and headlight aim must be checked if the vehicle ride height was changed.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
Old Aug 7, 2008 | 09:01 AM
454navyss's Avatar
here you go
http://www.stylintrucks.com/parts.as..._prod_ids=3359
Old Aug 7, 2008 | 12:06 PM
shakesvho's Avatar
yep, look at all this crap
