Truck is going in for surgery tomorrow
Old Jul 10, 2005 | 02:37 PM
vortec327's Avatar
Default Truck is going in for surgery tomorrow
Im getting the trans fully built and a 2500 stall put in. Should i get a better trans cooler? Which one should i get?
Old Jul 10, 2005 | 02:56 PM
i know b&m makes a good one. seeing that you have a radix and a stall coming, i would try to get the biggest one you can get. i think a few members on here are running permacools with no probs.
Old Jul 10, 2005 | 03:24 PM
thunder550's Avatar
High on diesel fumes
Tru-cool is good too, I have two of those. The problem with the popular B&M is that it is not as big of surface area and it is deeper. I got two of the Tru-cool 22,000 GVW coolers, they have a higher surface area and are thinner than the B&M, although both Tru-cool and B&M are made by Long Manufacturing. I put fans on both of them, and even towing a 6000 lb trailer up hill for several miles under boost, my tranny temp never tops 210. Normal operating range is between 165 and 180.
Old Jul 10, 2005 | 03:59 PM
99Silver6.0's Avatar
B&M 70264. Order that one.
Old Jul 10, 2005 | 04:02 PM
vortec327's Avatar
would you guys bother with a fan, or is it not needed?
Old Jul 10, 2005 | 08:48 PM
Keith's Avatar
On the cooler?
Old Jul 10, 2005 | 10:45 PM
vortec327's Avatar
Originally Posted by Fandango
On the cooler?
Yea think its worth it?
Old Jul 11, 2005 | 02:07 AM
thunder550's Avatar
I did it on mine for towing and because I live in AZ. Turning the fans on drops the temp by about 15 degrees or so. Try it without first, and if it's not doing the job then put a fan on later.
Old Jul 11, 2005 | 02:05 PM
Last Call's Avatar
TOTM: January 2007
You going to SMI? They have a lot of coolers in stock.
Old Jul 11, 2005 | 02:40 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Heres mine should do the trick
my tranny cooler
I tow all the time and go offroad and it does a great jon without a fan but I will be putting two 10" fans on it just for a little extra. Tranny usually sits at 160 cruising hottest its gotten towing was 190 in stop and go city traffic.
