Tru-Trac install...
Old Jun 3, 2009 | 06:55 PM
silver-mod-o's Avatar
Hunt&Fisherator
Default Tru-Trac install...
Ill be swapping out my stock G80, for my tru-trac shortly and I've got everything figured out except one thing LOL... How the hell will the axles stay in?!?
The rear is a 03 Z71 3.73/G80... The G80 uses C clips, and this Detroit has me stumped
I know besides that, all I need is new ring gear bolts, gear lube and check backlash, re-shim if needed and go... Right? Gears are going back in, not disturbing the pinion...
Old Jun 3, 2009 | 07:01 PM
00ChevyScott's Avatar
Wearin' da big hat
you reuse the same C clips.
Old Jun 3, 2009 | 07:23 PM
KySilverado's Avatar
Yep, re-use the c-clips. Then a spacer goes in between the axles and the cover to the access hole holds it all in.
Old Jun 3, 2009 | 07:48 PM
Hunt&Fisherator
Do you have to take out that snap ring to get in there?? I haven't taken it off yet to look... Just scratching my head like a monkey trying to open a rock
Old Jun 3, 2009 | 07:50 PM
Yes, remove the snap ring. It will all become clear. Damn I have enough pictures to sell a shop manual
Old Jun 3, 2009 | 07:53 PM
Hunt&Fisherator
I didn't want to take that thing off and the guts start coming out... That'd be my luck lately.
Old Jun 3, 2009 | 07:56 PM
To operate you have to get bloody
Look above, I posted the innards! FYI mine came with the plug already out. In a seperate bag with the spacer and lock ring.
Old Jun 3, 2009 | 08:16 PM
nonnieselman's Avatar
Ben, i cant believe you... Your suppose to open it up and then ask how to put it back together...
Old Jun 3, 2009 | 08:18 PM
texasbullseye89's Avatar
Ben, Im off Sunday if you need help with anything. Or someone to stand around and drool rather....
Old Jun 3, 2009 | 08:36 PM
Hunt&Fisherator
Ride on down... I'm sure Ill either be here breaking stuff or scratching my head and figuring out how to put something back together.
