Tru-Cool stuff
Old Aug 9, 2010 | 04:01 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Default Tru-Cool stuff
If you want to modify & use your stock trans cooler lines with your new tru-cool, here's a Napa part number. Inverted flare on one side, snap clip on the other side. 730-4953 BK
Also scanned in the box. Makes me worry less about cold weather use.
Old Aug 9, 2010 | 05:19 PM
budhayes3's Avatar
PT's Slowest Truck
Sooo, the trucool basically has an internal cold weather bypass already...pretty cool Good deal on the Napa PN for the fitting too, those are what I used that came with the EAD bracket kit.
Old Aug 9, 2010 | 05:51 PM
Maybe this post will help a few folks out.
Old Aug 9, 2010 | 06:06 PM
budhayes3's Avatar
PT's Slowest Truck
Absolutely, I was under the impression that the trucool had an internal bypass, but later was told otherwise. Guess that it helps to read the box
Old Aug 10, 2010 | 05:00 PM
qwank's Avatar
hey guys,
I just installed a B&M super cooler, part number 70268, ands its the EXACT same design for half the price. I think i piad $50 for it from summit. its the same with as the stock cooler but about 4" taller, and even uses the same mounting holes.
I forgot to take a picture of it yesterday when I put it in, but I'll pull my grille off later and take one.
my trans temp dropped 30 degrees.
part number 70266 is even taller and you can use the OEM fittings on it.
Old Aug 11, 2010 | 09:26 AM
04ColoradoZQ8's Avatar
Also for the 2000+ GMs this little piece will be helpful to some as well
Hayden 397 fitting: http://www.transmissioncoolers.us/Me...roduct_Count=2
Here is is on a 2004 Colorado:
Before:
Installed, no need to cut ot modify the factory trans cooling line!
Hopefully this can help you guys out, as some of you helped me earlier in the week with this same topic!
$A_Money$81
Mar 27, 2023 10:25 AM
cheyenne383
Nov 13, 2015 09:24 AM
drummer0415
11
Oct 24, 2015 08:16 PM
lxcoupe
Sep 25, 2015 12:36 PM
maxspeed05V
Sep 23, 2015 10:48 AM
