Tru-cool 40k is on!!
Old May 21, 2010 | 11:07 PM
Jeteys5.3's Avatar
Default Tru-cool 40k is on!!
However i have a question. There was not much fluid that came out of the stock cooler, maybe because the truck had sat all day. As in maybe 8oz came out, around enough to fill a small glass perhaps. Started up the truck and checked the fluid and it was still in the normal area. But i know this cooler will hold more, alot more, so do i need to add any? Or just let it run for awhile longer as in take a trip to the store then check it? or am i fine until tuesday when the stall goes in and fluid changed?
Old May 22, 2010 | 12:37 AM
bud8fan's Avatar
as long as it stays around the full mark you will be fine till the verter swap
Old May 22, 2010 | 01:12 AM
Dewey's Avatar
yup just keep an eye on it, because it may take a little bit of time for that cooler to fill up.
Old May 22, 2010 | 02:29 AM
1LOW4X4's Avatar
Banned
I drove mine a lil while and had to add like a lil more than half a quart.
Old May 22, 2010 | 07:45 AM
dewmanshu's Avatar
Moderately Differentiated
Yeppers, let it run for a bit and keep checking the level. It should drop eventually if not pretty quick IMO.
Don't forget to give extra fluid to your trans guy.
Old May 23, 2010 | 11:11 AM
Pooki's Avatar
Were are you guys buying your Tru-cool 40k from? I live in Canada and would like to pic one up.
D1SCSS
Jul 25, 2024 06:54 PM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
slowlsx
Aug 10, 2015 05:33 PM
Dirtywhite
Aug 5, 2015 04:10 PM
Ls3silverado
Jul 31, 2015 04:22 PM
