Tread pics of TOYO Proxes STII
#31
im running 32 out back and 36 up front. if you had them installed at a trire shop, those guys tend to royally screw up tire pressures. its either gonna be at 20psi or 50psi. dangerous **** there.
another good note...one of mine balanced with ZERO lead. =)
i have a c notch with my 4-2 drop....makes a difference for sure. i recommend the belltech kit....much better than the DJM. i have not seen a chasis tech or mcgaugheys kit in person so cant say. what shocks do you have and what are you changing to?
I am going with belltech street performance shocks after the recommendation from several members..
The Cnotch i will be installing is by mcgaughey, seems like a stout piece IMO...
#33
I just put on a pair of Proxes-ST II's. They are quieter than the old S/T and in a hard corner do not seem to squeel and scrub as much as the old S/T. I've only got them on only the front right now, the rear S/T's aren't ready to be swapped yet, so I don't have any feedback on dry traction. The sidewall pattern is barely noticable. So far I like them better...
These are size 275/55 R17.
#34
I can honestly say I like them! Wet traction was really good the other day when it rained I could get on the throttle hard and it never broke traction. Dry traction at the track was also really good, once I got them broken in a little bit. Street traction is also really good. My intial impressions were bad, but once I wore them in a little bit they are great. Also I really like the tread pattern too...
KINGCYCLES
10-02-2015 10:21 AM
