transmission trouble
Old Dec 5, 2009 | 04:27 PM
Default transmission trouble
well i have a 4l65e fully built i recently replaced my stall from a 3400 to a cirlce d 3800 4c i drove it for a couple days after install with no problems i took a 400 mile trip with no problem on my way back problems started.........
1st. temperature raised from 160 to 210
2nd would not shift into 3rd
3rd rpms would reach 6000rpm and still no shift
4th speed will not go over 45mph
what could be the problem?
Old Dec 5, 2009 | 05:11 PM
Circle-D's Avatar
Former Vendor
Sounds like a 3/4 clutch problem. Have you checked to make sure the fluid level is good. Get a scanner on it to see what is being commanded.
Chris
Old Dec 5, 2009 | 07:30 PM
Chris
I will do that I have purchased new solenoids and wiring for it just in case its an electrical problem............the fuel level seems to be at full what parts make the 3/4 to go bad or fail I know its not your stall it works great also i havent retuned it for the stall size went from a 3200--3400 to CircleD 3800 4C triple disc
calsdad
Jun 14, 2023 11:07 PM
bearden86
26
Nov 15, 2015 03:58 PM
dsbodley
Nov 14, 2015 09:46 PM
nabozny21
Oct 17, 2015 07:47 PM
jscherbs
Sep 30, 2015 07:54 AM
