transmission question
Old Jan 15, 2007 | 06:33 PM
whoopassracer's Avatar
Default trans problem
well today on my way back from work i gave it more than half throttle from 2nd gear to 3rd gear, from 2nd before going into 3rd it revved up a bit (like it neutrallizes) then shifts into 3rd and it dont do it during normal driving just when i give it more than half throttle
Old Jan 15, 2007 | 07:59 PM
RandomHero's Avatar
your transmission is slipping. Nonnielsman(sp?) had the same thing happen.
Old Jan 15, 2007 | 08:05 PM
so what could it be to fix.
clutches!!!!
Old Jan 15, 2007 | 08:28 PM
getchusum99's Avatar
i know that feeling....BURN BABY BURN........time to go into the tranny.check your fluid and see if it is dark colored and smells burnt...
Old Jan 15, 2007 | 08:36 PM
well it was low 1qt and have royal purple trans fluid, which have about 6months of use with it. the last time i service the tranny was about 2years ago when they put a new sunshell, z-pak clutches and the transgo reprogramming shift kit. my line pressure is stock except what the shift kit gave me. and ever since havent checked the tranny filter to see if it's restricting anything or if its to cold or something. cuz i notice when it's been cold the tranny dont lock up to overdrive until the tranny is warn. is this normal
Old Jan 15, 2007 | 10:04 PM
does being 1qt low, would this have anything to do with this problem
Old Jan 15, 2007 | 10:23 PM
phasemaster1's Avatar
My trans fluid level is fine and looks good dosen't smell burnt.
Old Jan 16, 2007 | 09:51 AM
Last Call's Avatar
TOTM: January 2007
Mine did the same thing... sluggish 2-3 shift. I turned out to be the 2-3 clutch band, it was stretched.
Old Jan 16, 2007 | 09:57 AM
I hope its not that jason. That would suck.
