Transmission line replacement?
Old Dec 24, 2010 | 07:23 PM
greenturtle05's Avatar
Default Transmission line replacement?
Ok when i installed my stall i was being lazy, and didn't disconnect my battery cables. When i was putting my starter back up it touched my tranny line and it burned a hole in it. I then made a quick fix, by cutting the line and splicing it back together with a rubber hose and 2 clamps. that lasted for about 10 months, and it started leaking. so i went to my local stealership and bought a new line. I got the new line installed, fired the truck up and f**k that's leaking. Rubbed a hole in it some how fighting trying to fish it through. Now i have to purchase another line. whats the easiest way to fish the line that goes from the tranny to the radiator, with out screwing it up?
Old Dec 25, 2010 | 02:16 PM
tallbluslpr's Avatar
when I have a line problem I go to napa with my lenght measurments give your self some extra and get a 3/8 or number 6 hydralic hose made to fit it and route it how I want I have good luck with this. you will have to do away with the quick connect and find a fitting to use on your hose may have to go to a hydralic shop but it is worth the time and money usually less than 75-100 bucks for both lines. And you are done with it for the life of the truck no more rubbing through
5.3Okasai
Mar 9, 2022 01:07 PM
thewrx
Aug 12, 2015 08:28 PM
76k10chase
Jul 17, 2015 01:48 PM
Nimoryan
Jul 5, 2015 03:50 PM
