Transmission line help
Hey guys, hoping some one could help me out here. The truck is a 03 Suburban with the factory towing package. I removed both hard lines from the transmission, and took them with me to the auto parts store to match them up. I worked a few doubles in between removal and install, now I forgot which one went where. One line went from the transmission to the radiator (lowest port), and the other line coming from the transmission went to the factory external cooler mounted in front of the radiator ( the port that would be closest to the drivers side) Which line goes to the top quick disconnect fitting of the transmission?
I appreciate you helping. One thing, the top fitting on the radiator ( i never touched it, still in its spot) goes to the cooler in front of the radiator. would this mean the bottom fitting on trans would also go to the cooler in front of the rad?
LPCWS6
03-25-2015 10:41 PM
2doorfury
01-22-2012 02:07 PM
bentrek
04-24-2011 08:28 AM
