transmission gauge question
i got a transmission gauge couple dayz ago and im wondering am i supposed to get a sensor for the tranny//? or where do i connect it to? do i drill into the tranny or etc can someone plz help me..
if any one has pix . or sketches plz chime in
You'll need a temp probe in the pan somewhere. If you want a near-stock install, newer trucks at least as new as '04 come with a factory pan temp probe already in the pan. Otherwise you can drill and install your own, or get a nice Mag Hytec pan for the 4L60E. Another pan available on Summit is a TCI knock off from the Mag Hytec pan, both linked below.
http://store.summitracing.com/partde...5&autoview=sku
http://www.mag-hytec.com/store/index...7abd5fde37dad2
My 05 does not have a probe in the factory pan nor have I ever seen one in a factory pan. Now the trans are wired for a factory temp gage in the cluster from 99 to present.
The Mag-Hytec pan and also the Mag-hytec diff cover have a plug for the temp sensor. I am running both on my truck.
have a good one.
Don
have a good one.
Don
formerly 1BADC10 (12/14/2011)
Was always curious about the possibility of using the stock resistor loop (trans temp) in conjunction with a trans temp gauge. Never pursued it. Guess in order to get that to work, it'd depend on the resistance requirement for a manufacturer's gauge. *edit* I think I remember the stock resistor is something around 100K ohms.
How about someone volunteering to try that out for the board.
Here's a schematic to get you started. Git 'r dun! ![Icon Lol](https://www.performancetrucks.net/forums/images/smilies2/icon_lol.gif)
![Nod](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_nod.gif)
![](http://i57.photobucket.com/albums/g210/alldata/TransmissionTemp.jpg)
Nimoryan
07-05-2015 03:50 PM
